Hello, hopefully this post is in the correct area. I've also posted in the HTPC thread.
I've recently put together a WHS 2011 server. It took a while to piece together, configure, install a few add-ins and start to transfer the files from my PC. I'm at the point now that I've transferred everything from my PC except my music. I've been holding off to make sure that I have everything set up correctly so that iTunes will work without any glitches after the transfer. I want to transfer all the music files to the server, but run iTunes itself on the PC. Is it as simple as transferring the music and then directing iTunes to the networked "//servername/Music/iTunes" folder?? That just seems too simple.
I've done a few google searches regarding this and I got some results for issues with installing iTunes on the server or for an iTunes add-in. So I figured that I'd check here on the forum for some advice. Thanks in advance.
