Just got the LCD2490WUXi.
I read about the A-TW polarizer causing a magenta and green effect in the corners, but I thought that was only when looking at the monitor from an angle.
Well I created a 100% black image and made it full screen, and I see that the lower left looks purplish and the lower right looks greenish, while looking at the monitor straight on. That is with my head approximately 18 inches from the monitor. If I move back to about 5 feet, then I don't see any purple or green (although there does seem to be some backlight bleed, especially in the lower left corner). But then I won't be using the monitor 5 feet away, I'll be using it 18 inches away. I thought H-IPS was supposed to eliminate the purple hue at an angle that S-IPS monitors suffer from. But it looks like it has introduced magenta/green corners straight on.
So what is the A-TW polarizer supposed to cure exactly? The white glow when viewed from an angle? Certainly a white glow from an angle would be better than magenta/green corners from straight on, no? I have access to a widescreen TN panel and a 4:3 S-IPS panel - can I use either one to recreate the white glow so that I can see what it looks like?
