rapperwith1p
- Oct 23, 2005
Ok so I'm about to pull the trigger on the Seagate 1.5tb hd from newegg but I was looking over some of the reviews (one in particular) and have some doubts.
The review said that the drive wouldn't be good for an OS drive due to its "weak queuing" capabilities...wth is this all about? I'm planning to only have just this one drive in my system with Vista partition of about 100gb and the rest for media and junk. My primary concern is the OS performance over what I have now which is a WD 500aaks drive and I find it fairly fast. Will the new 1.5tb hd be lagging behind, the same, or better? I noticed that the latency is basically cut in half which is a huge plus also.
Also, if I do order and when I get the drive I'm just going to do a quick format and go from there partitioning and installing Vista. I can't wait for a full format on a drive this big...is there a way to test the drive while in Windows where I can just run a program and call it and night, wake up and see if the drive will be ok?
I'm on the fence right now and I'd really like some opinions from people who own the drive and how it's working out for them.
Oh yea one more thing, what is the total capacity of the drive after formatting? Also, what sustained read and write speeds are you guys getting?
