masterofcows
- Dec 12, 2005
hey guys, i was wonderin if u could help me out with the Swiftech H220 APEX ULTRA CPU Liquid Cool Kit. like, i want a better tube thing and if u tell me which ones? i want tubes that are a little bit bigger then the normal size. and also, the cpu waterblock that comes wit it, does it fit on my amd athlon x2 3800? for my 7800gtx, which one is better? http://www.dangerdenstore.com/home.php?cat=48. i cant get the 100 dollar ones, so if u can sho me which one is the best there. thx guys
