Question.....
Status
Not open for further replies.
AceGoober
Live! Laug[H]! Overclock!
In several forums they allow for posting of system specs and pictures. Will [H]ardOCP be doing the same? Just a thought.
There is a case mod gallery subforum under the casemod forum in which you can post pictures of your case if you did something cool to it. I don't think there is really an area to just post system specs. Nobody really cares what anyone else has. This is a forum for support and discussion, not bragging. Though if you got something new and you want to share it then go ahead(in whatever forum is most appropriate for what you got). I bet you could start a specs thread where everyone posts specs, though. Might want to check with a mod on that. Also, your sig is about twice as long as it should be(max of 10 lines). Although it is not my forum and I don't have any say in what goes on here, so don't take my word for it.
Status
