question
It's a pretty simple process, after you've sat there a while and figured out what it is you need to know, do some research with google and see what you can find out. If there are still some things that aren't clear, come back here, login, and type your remaining questions into the post box. Just be warned that often times your question will evolve as you get further along, though it is perfectly natural.
