question?
Savidge
i want to know if 2 geforce gtx 260s would fit in a Thermaltake armor jr this is probrobly a noob question but ive heard of people putting 9800gtxs in these that are the same length while others say it wont fit...and before i spend my money id like to know ;) thanks
The layout is very much the same as my CM690 and three 280's fit in it just fine. It won't be spacious but they'll fit fine.
the cm690 is like 2 inches longer then a armor jr thats what im scared of
Just looked at the specs for both, the CM690 is only 1.1" deeper and there's at least 2.5" of space left in the case:
I got an 8800 Ultra in a micro case and its the same length as the GTX 260 and it just barely fit, it was touching the drive cage but it fit. It won't be spacious but it looks to me like it will fit.
