Question to Logitech MX500 Series Owners
Aztlan
have you gotten any wrist injury by using alot the mouse during gameplay or other stuff ?
I have a pain on my right hand wrist, is not major but it bothers so I have to cut down on usuage until I get another mouse that works on both hands
and until pain goes away
the odd things is that i have a mircrosoft intelexplorer 3.0 mouse that i have use alot and didnt gave me such pain
am I the only one?
Actually, I've had less hand pain since buying my mx510. I guess it's just a matter of personal preference. The big mouse really fits my hand well and feels comfortable, while smaller mice make my hand hurt. I have some friends who love tiny mice.
Either way, if it makes you hurt, you shouldn't use it.
I have a MX500 and I have no pain what-so-ever.. are you twisting your wrist when playing?
The only pain I get with my MX510 is from my wrist resting on the corner of my desk all the time & digging into my skin. It has nothing to do with the mouse though.
Maybe youre using the mouse at an improper angle (youre sitting too high or too low). Thats the only thing I can guess would be causing you pain. Try adjusting your sitting position.
Never had any pain using my mx500. Try getting a wrist rest so your wrist is more level while using the mouse.
With my MX500 my wrist feels much better than with other mice I've used. I have slight carpel tunnels in the wrist, but the 500 fits great and doesn't bother it at all.
Most likely you are using the wrong technique or your posture isn't correct.
I have the MX500 and had it for quite a while now. No problems whatsoever.
I hope that you have a seat with arm rests and that the arm rests are at the same level as the table top.
I often find myself having the MX510 at a slanted angle instead of purely vertical. Which means that I have to move my chair slightly to the right so that the right arm rest is vertical with the mouse axis.
