Does your keyboard show up as a 'Game Controller'?
Go into 'Control Panel' -> 'Game Controllers'.
Is it, or any device related to it, listed in the "Installed Game Controllers" window?
Reason I ask is that I'm using the Saitek Eclipse right now, and while it's awesome, it DOES show up as a game controller. Due to the way the keyboard is designed, in fact, it's ALWAYS controller '0'. This means that 'Indigo Prophecy' (and several other games) that just automatically grab the first controller and won't let you change settings is unplayable with a gamepad and this keyboard! You can never do anything to enable the gamepad device!
Quite frustrating, so I was wondering if the G15 had a similar problem, or would be worth consideration for that point alone?
