question to 2005fpw owners!!
latief75
when you first hookup your monitor using DVI port, does automtically go into 1680X1050 or do you have to install the driver first for that to be acheived ? i don't see that resoultion in my ATI 9800pro display properties ...
thanks,
Yeah, mine ran at 1680X1050 with my pro when I first hooked it up. Try installing the inf file that came with the monitor. The thing that did it for me was that I had my resolution locked using the old monitor instead of letting it query the monitor for the supported resolutions. There's a panel for it in the Catalyst drivers.
My ATI X600 Pro would't run it at 1680x1050 either unitl I loaded the inf file off the cd.
Pretty easy.
I never saw the 1680x1050 resolution offered on neither of the systems I use my 2005FPW with *UNTIL* i actually connected it for the first time.
You should have no worries :)
