newls1
- Sep 8, 2003
This is a little hard to type out the problem, but im going to try: Using 180.84 driver, (or any driver for that matter) when ever I try to game @ 1440x900 the monitor goes to 1408x900 for some strange reason, and it pisses me off quite honestly. I go into the NV CP and of course THE OPTION TO SELECT
1. USE MONITORS BUILT IN SCALING (THIS IS WHAT IT IS CURRENTLY ON)
2. USE NVIDIA'S GPU BUILD IN SCALING (WHICH IS WHAT I WANT)
3. NO SCALING
4. ETC...
ARE ALL GRAYED OUT AND WONT LET ME CHANGE ANYTHING!!!
I know my issue would be fixed if I can get the nvidia control panel to UN-GRAY this area so I can select "USE GPU SCALING OPTION" but I cant. To go over some of the following things I have done to make this a little more clear for you are:
I do have the monitor driver installed (Hanns-G 28")
I am using Win XP64 SP2 with all updates, and current DirectX download updates, etc....
Please, does anyone know of a "BACKDOOR" way of editing this option, and or a way to get them UN-GRAYED so I can change this setting? Thank you ever so much
3. NO SCALING
4. ETC...
