1Wolf
- Jul 10, 2007
Probably a simple question here...just about windows licensing and installations...
If I buy an OEM copy of Windows 7 for a new build, I understand that the installation is just for that build and that Windows will check for hardware changes to determine if it is installed in the proper computer.
What if I need to install multiple instances of Windows 7 in VM's and/or multiple installs of Windows 7 for a multi-boot/multi-drive scenario?
For example...what if my "main" operating system is Windows 7...but then I need to install a separate install of windows 7 on another drive dual-boot....and then...lets say I need to configure one or more VM's with Windows 7?
Do I have to purchase a separate copy for each time it is installed on the same machine? Or...because all of the VM's or multi-boot/multi-drive installs are on the same machine...will just one copy be fine?
If there is a limitation....does a retail copy have the same limitation versus an OEM builder's install?
Thanks!
Thanks!
