Question regarding VE278Q
Siamak8286
Based on the this information below, this monitor has Vertical Refresh Rate of 50 - 85 Hz, does this means i can play my games at 85fps?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236103
Display
Screen Size
27"
LED Backlight
Yes
Widescreen
Yes
Recommended Resolution
1920 x 1080
Viewing Angle
170°(H) / 160°(V)
Pixel Pitch
0.311mm
Display Colors
16.7 Million
Brightness
300 cd/m2
Contrast Ratio
ASCR 10,000,000:1
Response Time
2ms GTG
Horizontal Refresh Rate
24 - 92 kHz
50 - 85 Hz
Panel
TFT LCD
Display
Screen Size
27"
LED Backlight
Yes
Widescreen
Yes
1920 x 1080
Viewing Angle
170°(H) / 160°(V)
Pixel Pitch
0.311mm
Display Colors
16.7 Million
Brightness
300 cd/m2
Contrast Ratio
ASCR 10,000,000:1
Response Time
2ms GTG
24 - 92 kHz
50 - 85 Hz
Panel
TFT LCD
What games do you play and what GPU do you have? Also you can get more FPS than that if you disable Vsync, but given that info provided if you have good enough hardware it looks as if the answer to your question would be yes.
Those specs are very misleading. Yes, it does 85hz... at 800x600 resolution. At 1920x1080, you're limited to 60hz, unless you want to try "overclocking" it, which I haven't had success with yet (image gets squished to 960x1080 for anything over 60hz at 1920x1080).
