So here's my situation. (i want to make sure this i'm clear on this before I proceed and my brain melts)
I intend to upgrade a standard mechanical hard drive that I use mainly for storage. I need the upgraded/new drive (since its a direct replacement and has symlinks present) to be seen by the OS as the exact same drive for all intents and purposes.
Meaning, I intend for it to have the same drive letter, and I need the symlinks to still be functional.
Now on the surface I would simply disconnect some other drive (im out of headers) and connect the larger drive. Copy/paste the data over (should take a lifetime for 4tb) and then remove the source drive. Assign the source drives letter to the new drive, and be done with it.
My concern is if this is all I need to do, and would leave the symlinks intact/functional for 100% sure? If not, what would my solution be?
