Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I phoned them directly, which is the reason I'm posting this question. I didn't see this reference posted anywhere on the NZXT website. Anyhow, I spoke to a tech who told me I needed fans with RPM sensors for RPM reporting.
I found this very hard to believe, since this hasn't been mentioned in any review or can I believe every review subject had fans with RPM sensors.
Anyhow, I was hoping to hear YES. That the LXE will report the RPM value for any standard 3pin molex fan.
