Question regarding CPU clock by OS reading
techtips
hey everyone, I'm running xubuntu 15 on my x220 thinkpad.
Since we don't have CPU-Z, the next best thing is i-nex.
After installing it and browsing around, I noticed that under a CPUID tab, it has the following:
Clock by OS: 799 Mhz
CPU Clock measure: 2591 MHz
I've gone through all 4 CPU cores/readings and each one is identified as 799 mhz.
I don't really understand what this identifies, this 799mhz reading. Can anybody explain it?
Link to my CPU information:
https://i-nex.pl/inex.r?validate=061020159.27615046703622
Under idle, the cores clock down unless you have all power saving features disabled.
That is why it is showing all cores running at ~800Mhz - that is speed it runs at on the default low power state.
Once you put a load on it, it will clock it back up.
2.6Ghz is the base, non-turbo speed, which is where the 2591Mhz reading is coming from
Max turbo speed is 3.3Ghz. (probably when loading up one or maybe 2 cores)
Due to slight differences in clock generators, you are almost never going to get the exact rated clock speed.
Thank you very much cyclone3d! That explains it clearly.:)
