Question regarding a busted notebook LCD
c0ncept
I bought a Gateway MA3 model MX6447 notebook from a friend as is for $80, and the only problem is a busted out screen and a missing power charger. All else was working fine before the screen was damaged.
I've been checking ebay for LCD's to replace it, and most of them will list something like "Gateway MA3 LCD" for around $90-150 without mentioning the specific model number (like my MX6447). From what I've researched so far, there are several different laptops that fall within the MA3 boundaries.
What I'm wondering is, do you think if I just bought one from ebay that says "Pulled from a Gateway MA3," would it work on mine? I really don't want to order some LCD that won't fit in mine or something.
