Question re: Sleep mode and system heat
schoenda
So, forgive me, not sure where to put this, maybe better under op systems...
So obviously some power is being consumed in sleep mode, or dual hybrid standy or whatever its called, to keep mem in RAM...so with no fans running how can there not be a danger of overheating? I assume this is just a trickle of juice but what if you have an oc'd system and ram is running hotter than stock?
I know this is a mundane question but I would very much appreciate an answer...can a system running Vista that is overvolted and water cooled, (no fan to switch on), overheat in sleep mode?
As always..thanks!
-Dave
Fans are off in sleep mode; so the processor isn't running; only occasion voltage to the ram to maintain memory, I believe.
