Hi.
I use Windows XP Home Edition and I've just bought an Intel i7-920 processor and I'm planning on buying either an Asus P6T SE or an MSI X58 Pro-E motherboard. My question is in regard to DDR3 memory.
It's my understanding, and I could be incorrect, that the maximum memory XP can hold is 3 or 4 GBs. I've been told by a friend of mine that I should probably by 4 GB of DDR3 memory. But I see, for example, on newegg, that there's DDR3 1600 (PC3 12800) and DDR3 1333 (PC3 10666) [there may be others, I don't know]. I also see that memory can differ by "Cas Latency," and I don't know what this means.
I want to buy the "fastest memory." Can anyone make any suggestions?
[By the way, I'm planning on changing to Windows 7 in the future but not right now]
Thanks again.
Thanks again.
