MrChampion
- Dec 14, 2008
I am about to order my hardware for my first comp build. However I just realized that My desktop needs wireless connectivity in my house because the router is downstairs and snaking cables would be too much of a hassle.
What makes for a good wireless card in a desktop? looking on newegg theyre all priced around 20 to 40 dollars so cost wont be a limiting factor. However In the order I will place I am getting a http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359 as my mobo and...
well I was about to add the 4870 1gb vid card but it seems as I was writing this post newegg has run out of stock... I guess that means ill go with the gtx 260 216 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130398
I guess this doesnt change my question. In combination with this video card and the mobo I plan on ordering, I should still have the open slots to add a wireless card right? I heard that the gtx 260 is large enough to cover up other PCI slots.
PS: also since it looks like ill have to order this card instead of the 4870 (if it is not in stock by the time i order) will this gtx 260 fit in a CM 690 http://www.provantage.com/cooler-master-rc-690-kkn1-gp~7COOL023.htm case easily enough? Ive read that this card is a behemoth
