Question on where to position case fan.
avial
I recently purchased a Coolermaster Centurion 534 +Plus (http://www.coolermaster-usa.com/Products.aspx?pid=1202) and am curious how to best position a fan I bought for the side of the case. It currently has 1 120mm fan in the front acting as an intake fan, a 120mm intake fan on the lower side of the case, and a 120mm fan acting as an exhaust in the back of the case. Since I have an Arctic Cooling Freezer 7, I couldn't keep the air duct on the side case, so I removed it. I bought a 80mm fan to put in its place. You can check out what I mean by visiting this link: http://www.coolermaster-usa.com/ProductImages/1202_4.jpg
Anyways, should I position the 80mm fan as an intake or exhaust fan? Thank you very much for your help.
def intake will make ur gfx card run heaps cooler like the poster before said
