Question on wc
tumnarak
I am new.
My system:
E6600
Commando or some of 680i
XFX 8800GTX or XFX 8800 GTS (only single I will buy)
G.skill 2*1 Gb HZ
Enermax Liberty 500wat
For my WC System all of my system will be 1/2"
Pump : Danger Den DD12V-D5 Pump or SwiftTech MCP655™ 12 VDC Pump
Radiator : PA120.3
VGA Block : MCW60 with ram sink
Chipset : I don't know what I should get but I looking for MCW30
Tube: Tygon but I don't know which one will suitable for my system
CPU Block : AquaXtreme MP-05 but there are SP and PRO version which one should I go for
Coolant: please give me sugggest I want UV
Reservoirs: Is it easy to make it by myself or just buy one
This is my first time to build WC system.
Why do u recommended Swiftech Microres?
Swiftech is quiet, but small and a bit of a pain to fill. If you have space get something slightly larger like the EK150 or 200, but if not the Microres is fine. Swiftech is cheap though so if budget is an issue it's a good deal.
UV fluid - Thermaltake makes some. You can also buy UV dye and add it to distilled water/coolant combination. Not sure how well the UV dye works.
what are the other thing ? Do they ok?
The rest is good.
I'd try to get the Dtek Fuzion for the waterblock, rather than the MP-05.
Get Masterkleer 7/16" tubing if you can find it. Much cheaper and safer (no leaks!) than Tygon.
For UV dye, I suggest using some Dtek UV dye. It's really amazing stuff.
Thank you for your answer
If I get Dtek Liquid How can I make coolant.I know use distilled water.Do I need to put something in rather than Dtek Liquid
You might want to rethink your PSU choice. The 680i MB's along with a 8800GTX is a bit of a power hog. I am running a eVGA 680i MB with two 8800 GTX's with a PC P&C 1Kw PSU. My rig is H20 cooled as well. You have to take into account your entire load including the H20 cooling, pump and monitoring hardware. I would suggest this PSU http://www.pcpower.com/products/viewproduct.php?show=S75QB
