ok i am testing my new system right now inside the case without the pc parts in. i am wondering do i have to take everything apart and then install the mobo and the watercooling kit what do you guys recommend?
You should be able to put your mobo and other stuff into the computer with the watercooling gear already in there. If you can't then you did a poor job planning this whole thing out. There really is no point of connecting the watercooling gear in the case if you dont intend to fit everything in there. It also makes no sense to take the gear out, dissasemble it, then put it back together again. Why cant you take the watercooling gear out in one piece with water in it?
