Question on vdroop with 750i & e8500
pirate1
Hi all. I've got a question. I just built my first rig and did my first overclock. I used an evga 750i with an e8500 cpu. 4GB of corsair dominator(2x2GB) 1066 ddr2 memory. 750w corsair psu. velociraptor hd. 2x xfx9800gtx in sli. Samsung 20x cd/dvd burner. Sceptre 24" lcd monitor. Using a sunbeam core contact freezer(air). Anyway, I got my rig together and booted first try, loaded xp pro all with no problems. Overclocked the fsb to 1700 and the cpu core to 1.3v. Input the stock setting for the memory. 1066 at 5,5,5,15 and unlinked the memory and cpu. Everything went fine, ran prime 95 for about 6-8 hours three different times and it all seems real stable. I figure it should be I'm not really pushing it very hard. I'm running the e8500 at 4.03mghz at those settings so there should be plenty of room left. I didn't want to get too radical my first time out.
So the question is, I was expecting the actual voltage to be a little lower than what I set the core voltage at. It was the first couple of days but now I'm seeing 1.3 to 1.32 actual on CPUZ. It seems to bounce around without much load on it. Is this because of something I missed or didn't do or is it just normal for this setup?
I forgot to mention the memory voltage is set at 2.1v(spec) and the temp is idling about 64 and when running full load goes to 69-70 with spikes to 71 or 72 but basically staying at 69-70. That's after running prime 95 for hours while I listen to slacker and surf at the same time. Actually surprised I could do that at 100% load.
A bit of voltage fluctuation is perfectly normal. As long as your system is stable, there's nothing to worry about.
