QUestion on new build
bgrob26
Hi Im building a new comp and wanted to get a few opinions on how well I did.SO do You think think is a good build ? or would you change something"please state why"..thx
CPU: Intel Core 2 Duo E6600
Heatsink: ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink
Mobo: EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard
Ram: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit "timings 4-4-4-12"
Video card:XFX 8800gtx
p.s. ordering it tommorrow so quick replies would be Nice :)
looks fine except for the missing hard drive, case and power supply.
For a psu, depending on your budget and if you want to go sli or not, the Silverstone ST75ZF is a good choice, as is a Corsair HX 620 (with pci-e adaptors to run sli) and an HX 520 (no sli) too.
oh ps is a Thermaltake PurePower 600watt and the HD wdse 250 gig...thx for the input thus far.
