Question on mounting hard drives.
How would your ideal case have it's HDDs mounted?
  • Classic style - aligned with the case in the middle or bottom
    Votes: 14 46.7%
  • Sideways at the top front or back of the case
    Votes: 2 6.7%
  • Sideways at the bottom front or back of the case
    Votes: 10 33.3%
  • Somewhere else (link to example or describe)
    Votes: 4 13.3%
  • Total voters
    30
uzor
I've been thinking off and on about building a ground up costom case for my comp, and one thing I'm undecided about still is the HDD mounting mechanism. Should they be up front middle/bottom aligned with the case (classic style), mounted sideways at the top? sideways at the bottom? somewhere else entirely? What do you think?
Sideways in the front like the armor jr add on kit for the WD 150 Raptor so you can see it spinning. =)
Thanks for the replies so far. For those just looking, go ahead and vote even if you don't leave a comment.
Susquehannock, what advantage are you seeing in that mounting mechanism?
Here is how mine is mounted
I thought the best design is to mount hard drive at the bottom of your case because heat rises, and your front fan will then push the heat that rises up, and then the rear fan do the rest. If your hard drive is elsewhere, then you can't get that benefit.
Did not see your question before .... sorry.
Advantages? ...... nothing major but here are a few of my opinions, and couple things others
mentioned which I hadn't thought of.
Please feel free to share your thoughts & critisisms. Have another design in mind & would
appreciate the input.
_____________________________________________
~Practical~
1] - easy to mount right behind bottom front intake fan
2] - rack has open design so air travels freely around drives
3] - hotter side of BOTH drives face toward center where airflow from front inttake fan is greater
4] - drives face opposite directions so lateral forces act against eachother helping to eliminate harmonic & mechanical
vibrations in the rack
5] - rack has only two mounting points - Easy to dampen vibrations
6] - both mounting points at one of the most solid parts of the case - the bottom.
~Asthetics~
1] - drive position places the more interesting side of drive toward window
Would also add that in the past I had two Raptors in one of those racks which are among the
most noisy & hot running HDD's. = Cool & quiet.
images again for convenience ~ -rack1- ~ -rack2-
