- Aug 16, 2004
Anyways, my old but good condition Antec Performance case has a few problems with the brass screwed in motherboard standoffs.
They are ruined since when the brass standoffs are tighten all the way, they still move, which means the threads are wiped away.
I am looking for those plastic ones, but do you guys know which specific version I would need?
http://70.169.170.235/acatalog/Motherboard_Standoffs.html
There are two types, the "sliding" ones and the "hole" ones.
Thanks for your help.
