I'm looking to make a small HTPC, it won't need that much power yet. Currently all I need it to do is display SD and do some emulators, however in the future I would like to be able to view HD content, so I would like my MB to upgradable. I've been looking into the Intel based MB because I would really like to upgrade to a conroe based chip in the future, but i'm having a some trouble.
here are some requirements:
Micro-ATX
Low-Cost -- I don't want to much over $100 for the CPU+MB right now
Low Power, low-Noise, low heat.. Since this will be a HTPC I don't want to have to put a screaming fan in there.
Linux -- I'm using mythtv so it'll need to work in linux
I was looking at this one:
http://www.newegg.com/Product/Product.asp?Item=N82E16813157091
Since it suppose to work with conroe, and it seems like the right price. however it's AGP and I would like PCI Express for the future. And even if it was exactly what I was looking for I have no clue on what Intel CPU I would get.
So does any one have any suggestions on a conroe compatible MB, and a non-conroe cheaper CPU to go in it?
Thanks
Micro-ATX
Thanks
