Question on LCD's
FortySix&2
K, Not sure if this is the right place to be posting but it seemed the most related.
Has anyone used the Matrix Oribtal display: GLK12232-25-SM. Dont get me wrong I really like this display and I wanted a graphical LCD but I cant get this thing to ever cooperate. I was using a plugin for winamp by Zehnedar. I know because it is a graphical display it has less software but now I cant get any software to work. Are any of you using this LCD and what software are you using. LCDC, LCD smartie or what. It either displays nothing or half words. Ive read that alot of software still works with some tweaking. Well I've had enough tweaking, is anyone gone thru these dilemas.
Okay, Forgot to mention that the winamp plugin and the Matirx Oribtal Graphical display program both can turn on/off the backlight and contrast, just no text is displayed when sent.
sounds like a connection problem to meh?
read the faq <--- insert "read the faq" pic here.
on LCDs...
I went thru the FAQ before I posted I really didnt see the answer to my question. So I posted. Of the four wires does anyone know which handle data transfer.
