Looking to water cool SLI 1080's. Not sure a single 120mm rad would be enough to cool both cards once oc'd -- so was thinking of going 240mm.
The front side of the Area 51-r2 has 2 120mm mounts on the internal side of the front bezel, but there's about a 3" gap in between them -- getting a standard 240mm is possible but I'm trying to avoid having to come up with a work around to mount it.
Was thinking of doing the following-- (the water lines are just flow path). Don't know if its even ideal to be daisy chaining 2 120mm rads in succession...
Appreciate any feedback and definitely open to suggestions...
Thank You
Thank You
