- May 2, 2006
I am looking to upgrade from my AMD 965 for various reasons. Would an i5 4670K be overkill for gaming with a 7950?
There is no such thing as CPU overkill on a modern gaming machine when you consider its speed.
There are a few games that need more core speed than is available, even when highly overclocked.
A few games can use more than 4 cores and give a small benefit.
SLI/crossfire and x3, x4 use more CPU as well.
Most games will run great with a stock clocked modern intel CPU.
To give yourself the certainty of getting the max from all games, get a K series chip,an overclockable motherboard (not an H series), a good CPU cooler and a case with good airflow.
Yep.
For now at least, see where we are after a few years of 6+ core consoles.
Dont be such a dipstick.ROFL.. do you actually think that the games that are being developed for the PS4 and Xbone systems (which both have 8 core 1.75/1.6Ghz amd cpus) will actually cause the PC games in the future to be "bottlenecked" by a 4670k?
Really?
Agreed, my point was that PC games can make use of more cores, not that next gen consoles will beat PCs.I do not think the 4670k is overkill at all for a 7950. I also think that these next-gen consoles with increased cores will only teach developers how to utilize and spread the load more efficiently, but they will not touch the performance of a 4670k
Blah
