FlintMurdock
- Sep 20, 2006
I have a mild overclock on an X2 4800 (2.7 on 1.4 volts) and I noticed while running Orthos that core 1 was running at 42c and Core 2 was running 53c. Is it normal for dual cores to have such a temp difference between each core, or does my waterblock need to be reseated? I was thinking that since the IHS is still on, that it should conduct the heat evenly to the waterblock, but since this is my first dual core overclock I am not so sure. Any suggestions are greatly appreciated.
