Puchi Kitsune
- Dec 2, 2009
I am going to admit from the beginning, but I am a noob. Last time I have build a system was when P3 733Mhz was still around, and my current machine is P4 3.2Ghz from 2004.
I remedy my lack of a decent machine, (and to actually spend my yearly salary bonus somewhere, not to mention the fact that I still have a job), I went with custom build machine from iBuyPower. I needed something that could run Dragon Age: Origins as well, so that I may disappear into that void for the next year or so.
Specs below...
But this is not about what I have gotten... I have a question about CoolerMaster V8 CPU fan...
I am looking at my new pc right now, (yes, it is finally arrived) and I have noticed that V8 is kind of loose. It pivots from side to side, but otherwise it sits solidly on the base.
Does it have to be that way? Is it loose by design to negate it's weight on the motherboard when machine is standing up right?
Anybody familiar with this fan that may put my fears to rest?
Comments feedback on overall build are welcome.
Thanks.
Specs below...
Case (CoolerMaster HAF 922 Mid Tower Gaming Case - Black)
Processor (Intel® Core™ i7 960 Processor (4x 3.20GHz/8MB L3 Cache))
Processor Cooling (CoolerMaster V8 CPU Cooling Fan System)
Memory (6 GB [2 GB X3] DDR3-1333 Triple Memory Module - Gaming Series Brand)
Video Card (NVIDIA GeForce GTX 285 - 2GB - Single Card)
Motherboard (ASUS P6T -- Intel X58 Chipset CrossFire and SLI Supported w/7.1 Sound, Triple-Channel DDR3, Gb LAN, S-ATA Raid, USB 2.0, 3-Way SLI PCI-E MB - 3-Way SLI)
Power Supply (850 Watt -- Corsair CMPSU-850TX Power Supply - SLI Ready)
Primary Hard Drive (1 TB HARD DRIVE -- 16M Cache, 7200 RPM, 3.0Gb/s - Single Drive)
Optical Drive (22X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - [Lightscribe Technology] Black)
Sound Card (3D Premium Surround Sound Onboard)
Network Card (Onboard LAN Network (Gb or 10/100))
Operating System (None- Pre-formatted Hard Drive Only)
Advanced Build Options (iBUYPOWER Specialized Advanced Packaging System - Protect your investment during transportation!)
Advanced Build Options (Tuniq TX-2 High Performance Thermal Compound - The best interface between your CPU and the heatsinks)
Advanced Build Options (Professional wiring for all cables inside the system tower - Achieve exceptional airflow in your chassis)
Thanks.
