tsuehpsyde said:The eVGA lifetime warrenty + overclocking + coolerswapping will definately get them more sales with the enthusiast market, and yes that will come with a few idiots who mess up their card physically and send them back broke and try to hide it...but I think eVGA is aware people are always going to try and bone them (it happens to every company, reguardless of how you word the warranty), and this opens a window for people who "responsibly" (keyword here) optimize their card without voiding the warrenty. As long as volt modding stays [H]ard, I think this policy will work well for eVGA....but if voltage adjustments come in the form of software, I think this warrenty service will have to get a bit of a tune-up.
tsuehpsyde said:I would like to just say thanks to eVGA for taking the side of the enthusiast. I wish more companies would take eVGA's stance on their products.
I'm not sure if you saw my keychain ( http://link removed ), but I turned one of eVGA's cards into a keychain as I had voided the warranty with my tinkering and it had died. Not what I wanted to do with the card, but I'm not one to screw over a company because of my own actions. I was questioning if I shoulda went eVGA again, as all cards are basically the same except for the warranty, and after reading your posts that basically say that if you know what you're doing and don't physically damage the card, it's still under warranty, I can say I'm happy to stay aboard eVGA again. I just ordered your e-Geforce 7800GTX about 10 minutes ago, then I jumped on here to see your auction to donate all proceeds to Hurricane Katrina victims. Glad to see you're giving back to those who need it.
But I want to make sure I'm correct with my assumptions. If I overclock my videocard, as long as I don't voltmod the card, it is still under warranty, correct? Also, if I swap out the videocard's cooler for an aftermarket cooler, as long as I don't damage the card itself and put the original cooler back on, it's still under warranty, correct?
Keep up the good work, and thanks for having a presence in the [H]ard|Forums.
-Jim
As you can see, he doesn't say "Sure, go ahead and overclock it." but he also states it doesn't void the warranty. For me, this is sufficient for my needs. Hell, my 6800 Ultra that I turned into a keychain was in perfect sorts physically...I just had a warranty that was void that I diddn't intend to 'dance around' for my own benefit.jdarwin said:Hi there,
Thank you for sticking with EVGA and we are here to support you!
Yes, you are correct, as long as you have no physical damage to the card then we will warranty the product.
As for the cooling, you are welcome to use your own solution but if you need to RMA the product you will have to put the original cooling solution back on the card with no damage.
Hope this helps and if you need anymore you can email me directly at xxx@xxx.
Thanks
Joe Darwin
tsuehpsyde said:Well, this is what I have in writing from Joe Darwin, who is an eVGA employee (their marketing director with a custom title in these forums). It is a bit dodgy I agree, but it does state that I can overclock and cooler swap without voiding my warrenty.
I think they're more pointing to a smashed off capacitor or a cracked board, something that's more "user error", more than the fault of something smaller caused by general use. Either way, overclocking does not void their warranty, as stated above. Therefore, if the card just dies while in use, overclocked or not, it's covered by eVGA, unless a cap blows on it or something....but remember, they'd still warrenty the card if it was stock speeds from any company, so overclocking doesn't change that. eVGA just loses the ability to point to that as the problem (and unless you overclock and don't watch tempatures and such, you really are asking for problems).UltimaParadox said:If you o/c and it dies, in no way was it perfect physically, something burned up and you just couldn't see it. That is where the problem lies, if you o/c and your card dies, something is physically wrong, even if you can not see it with the naked eye or not. Because it could be a tiny resistor on the card. So basically your warranty is void.
Back to the point though what does a post on the forum stand up to when it comes to warranty disputes... nothing.
tsuehpsyde said:I think they're more pointing to a smashed off capacitor or a cracked board, something that's more "user error", more than the fault of something smaller caused by general use. Either way, overclocking does not void their warranty, as stated above. Therefore, if the card just dies while in use, overclocked or not, it's covered by eVGA, unless a cap blows on it or something....but remember, they'd still warrenty the card if it was stock speeds from any company, so overclocking doesn't change that. eVGA just loses the ability to point to that as the problem (and unless you overclock and don't watch tempatures and such, you really are asking for problems).
Either way, I run their stock overclock of 450/1200 daily because it doesn't overclock much and it's fast as Hell stock anyway. And I plan to step-up to a 512MB version, or the GTX KO ACS3.
tsuehpsyde said:If I overclock my videocard, as long as I don't voltmod the card, it is still under warranty, correct?
That was a direct response to my quote. He diddn't directly say the word overclock, but he replied to my asking "If I overclock....it is still under warrenty, correct?" and he says Yes. Black and white, sir.jdarwin said:Yes, you are correct, as long as you have no physical damage to the card then we will warranty the product.
tsuehpsyde said:Here's your "in writing" statement from their marketing director.
In a PM from an eVGA employee, it means everything, sir. I'd hope eVGA would stand by THEIR word, being as employee's are what a company consists of. I've also called eVGA tech support and asked if overclocking voided the warranty, and they said the same thing Mr. Darwin has said. I have absolutely no problem sending back an overclocked card to eVGA for RMA. If eVGA refuses to take back their card because overclocking voided the warranty, they would be contradicting themselves and would lose quite a few customers, myself included.UltimaParadox said:In writing as in the actual warranty, forums posts = nothing
tsuehpsyde said:In a PM from an eVGA employee, it means everything, sir. I'd hope eVGA would stand by THEIR word, being as employee's are what a company consists of. I've also called eVGA tech support and asked if overclocking voided the warranty, and they said the same thing Mr. Darwin has said. I have absolutely no problem sending back an overclocked card to eVGA for RMA. If eVGA refuses to take back their card because overclocking voided the warranty, they would be contradicting themselves and would lose quite a few customers, myself included.
It's common sense, sir. Just because Joe Darwin's PM's and emails diddn't come packaged in my 7800GTX box, doesn't make them any less true or tangible.
It is in writing. He obviously wrote it for it to show up in my PM box. Or perhaps he has telekenetic powers of mysetery...ooooooooo. Sorry, but I diddn't want to ask the man to write it in blood and sign it with the spilt blood of his first born.UltimaParadox said:It does when you are trying to get your money back, always get it in writing thats rule number 1.
tsuehpsyde said:It is in writing. He obviously wrote it for it to show up in my PM box. Or perhaps he has telekenetic powers of mysetery...ooooooooo. Sorry, but I diddn't want to ask the man to write it in blood and sign it with the spilt blood of his first born.I think a PM and emails from his eVGA email account will suffice.
