Well I'm currently working on a build and it isn't a regular one. I've assembled PCs before, no problem, but this will require some modding. Since it the subject of these questions vary alot I decided it would be best to put it in "General Hardware" so I wouldn't have to made a seperate thread for every question.
So here are my questions:
MOTHERBOARD
(1) Now I happen to know I can remove some I/O ports and still have the motherboard work by disabling it in the BIOS, but how about moving it? I don't really need to move them far, it's rather positioning. If I bust the metal boxes but leave the wiring intact would it still work?
(1b) Is it possible to get a Shuttle Form Motherboard without actually buying a ... Shuttle?
GPU
(2) Are there any aftermarket Vapor Chamber coolers? I know Sapphire has them but I'm not interested in the card, just the cooler. How about reference coolers (in general), any way to get them without buying the GPU that's attached to it?
FANS
(3a) Are there any fans that work pure horizontally? You're probaly asking yourself what the heck I mean. Let's take graphic cards for example. The air is drawn into the card (vertically) and is blow throw the card (horizontally) out of the case. So I'm looking for fans that draw air from 1 side and exhaust it on the otherside, thus the airflow is completely horizontally.
(3b) How about blower fans? Where can I get those? Centrigufal/squirrel cage fans, same thing. I don't mean those flimsy $2 piece of ****. Quality fans.
PSU
(4a) I'm looking for a PSU, about 1.5-2.5" inch in height. The problem tends to be the length, some reach up to 300mm. Isn't there a series that aims at compact PSUs? Or atleast a specific way to search for PSU based on height? Or how about taking it out of the casing to reduce its height, any guide for that? I don't want to zap myself.
(4b) How about picoPSUs, are there any capable of powering a HD5850?
COOLING
(5a) Those liquid cooling glossy packs in laptops, (a) what are they called, (b) is it possible to buy them somewhere and (c) how effective are they really?
(5b) Has anyone tried using GPU heatsinks on their CPU? I'm interested because the're capable of dissipating alot of heat without having it stick out for atleast 3 meters.
Thanks in advance!
MOTHERBOARD
GPU
FANS
PSU
COOLING
Thanks in advance!
