Question: how does a CPU bottleneck a Video card?
Bowhuntr11
How does it? I was asked this recently, and I knew you needed a decent CPU to get the performance out of the Video Card, but I really dont understand why. I googled it but couldn't find anything. So anybody care to explain to a clueless one? :p Thanks!
My small understanding:
3d performance is largely a combination of two factors: cpu ability and gpu ability (the ram, hd, etc play a part but it's less pronounced).
Not enough gpu, and you could match it with a variety of cpus / cpu speeds and get similar results.
Not enough cpu and you could increase your gpu and not get that much of an improvement.
Yesterday, I swapped my very overclocked 7900GS for a fast 8800GTS 320 OC (and overclocked it more as well).
But because I have a single core 3700+ cpu... the improvement was not as much as the card is capable of.
Here's the results: http://hardforum.com/showpost.php?p=1031327199&postcount=13
So when I eventually scrape up some cash and get a Core 2 Duo rig, I should get another performance increase from the 8800gts.
