Question for y'all...
ShredderFan
I'm looking for solutions to back up more data...and I was wondering what ye thought of the available solutions..
The Western Digital Passport to Go is my first choice. Get 4 160 GB drives, eliminate the need for a power plug, and only need one USB cable to power them on. I just wish they came in bigger sizes, unless another company makes something similar..
Or, I could get a internal hard drive enclosure that could connect a few 700GB drives together. That would work, But do they make any that are powered on by USB, and have Sata Connectors? I could get one WD to go Passport drive for travel, and one of these for home and be ready to go...
You're out of luck for bus powered USB 3.5" enclosures. There do seem to be bus powered Firewire enclosures, but I didn't find any SATA ones(UDMA yes). 2.5" drives look to max out @ 200GB, so you're stuck with that being the limit. You could get a 2.5" USB enclosure & a 200GB 2.5" drive, but it'll probably cost you some dime.
