Question for UV Fan gurus
AliceCooper
Can anyone recommend a green 140mm UV reactive fan? I have been looking around, but they are either noisy with low cfm/pressure, non-existent, or are discontinued. The only one I have found is the Nanoxia CoolForce 140mm, but they are impossible to find. I wish GeLid would make a 140mm green fan :(. If possible I would like them to have decent air flow as they will be used on a rad, thanks.
I was looking at those, but was looking for more UV oriented stuff. I ended up finding one case that fit my vision in the mean time so I was able to use my AC Ryan's I had. Thanks for the suggestion though :).
Yeah, there are a good amount in the 120mm flavor, but I couldn't find any 140mm. I picked up three of the GeLid's, they are arriving today.
