I'm about to go buy this for a monitor, and I was wondering if it's worth it to get a HDMI to DVI cord, or could I just use the VGA connection. Is there a difference in picture quality?
I run the xbox 360 through the VGA, looks great. I'd run it with HDMI if it had discrete codes for the 4 inputs...that's the only bad thing. Sucks with a harmony if you use more then one HDMI input.
I'd say yes..though for me I never had a dvi connected display to begin with so some of the limits aren't as noticeable to me (shadow effect with text). Its plenty sharp for me, but the fact that you're asking to begin with tells me you should probably get the dvi-hdmi cable to get the most of the display
