Question for Ninja owners
ococ
Ninja owners. Do you use more than 1 fan on it (not including system fans)? If so, what direction is each fan facing?
I'm only using one fan (the one that came with the ninja plus). Pushing air through the heatsink and towards the back.
1 fan, pushing the air back. Although using the Antec 180, I also have two 120mm fans at low speed very close to the heat sink sucking air through it. So, you could say I have three. :D
