I have 2 cable modems in my home one with 50mbps / the other with 35mbps internet through comcast.
My desktop is connected via wirelessly to the 50mbps modem . My question is it possible for my desktop to connect to the other cable modem while still being connected to the 50mbps modem? Since my desktop uses a asus wireless adapter I was thinking about getting a power Ethernet adapter from my desktop to the 35MBPS modem . A power Ethernet adapter is to plug into the wall using electricity with cat 5 which will give me a theoretically speed of 500mbps which is plenty for my internet connection. I have a gigabit lan port on my pc which will be connected to a power ethernet adapter in the wall outlet.
My goal is to be able to utilize both networks and bandwidth on one PC. So for example I am on a downloading a game using a 50mbps connection and then surfing the internet using my 35mbps connection. Utilizing both cable modems with different IPs . Will windows 7 be able to determine which program is using what internet connection and is this setup possible?
Thanks
Thanks
