Question for Antec 900 owners
CantAimWhenDrunk
I understand that the total height for this case is about 18 inches. It seems that the height tapers down a bit towards the front of the case.
Can anybody tell me what that height is, right at the front of the case?
Thanks.
Note: That is the measurement of the front of the case height, not the height off the ground with the height of the little rubber feet added.
Do you know the height from ground level? The reason I ask is I wanna be sure I can reach inside the area of my desk where the case is going to sit when I turn the thing on.
I tore the rubber feet off to put caster wheels on, but if I had to guess... It probably adds another 3/8" to the height.
