Question Dual RaptorX case
Harvester
Hi all,
I'm new here, jeeej
Been reading alot of topics, seeing tons of pictures in the hope of finding a solution for my "problem"
I plan to add 2 Raptor X (raid 0) in my next system and I can't really find a decent case and/or solution where I can show of BOTH Raptor X's.
Certainly someone must have done this before me :confused: or at least seen 1:)
Any help or tips or links or pictures are welcome ^_^
The end system is supposed to be extreme in both looks and speed.
I'll start of with 2 raptors, use an upcoming X48 mobo, install Nvidia SLI, watercooled and if possible give it a theme (Starcraft 2)
well I am no expert here, but my suggestion to your problem is either build your own case that its focus would be the HDD, get one of those clear acrylic cases, or may even go with a case such as this one and do a little bit of modding to make it where you can atleast see one of the HDD with the help of something like LEDs or Cold cathrodes.
sorry I dont really have to offer but If i was doing something such as you I would either build my own case or just get creative.:rolleyes:
p.s. what ever you do keep us posted and most defeninatly provide some pics.:D
The Coolermaster Stacker 832 has an optional WD Raptor HDD Rack. No idea where it goes etc. but it has blue LED's. clicky clicky You'll find pic's of it in the gallery section.
The raptor mount in the 830/832 is in the top where the fan mount is, you switch out the plastic fan holder for the raptor tray. From what I can see looking at mine, it would be plenty visible with LEDs, and if you're up for a bit of modding you could easily fit two. I can snap a few pictures if you want to see it :)
Get a Shuttle P series chassis, the hard drives are installed on the top. Then put a window on the top. You have a nice, small and sexy case that prominently displays your hard drive pr0n.
