Question / anyone anwser it?
pblou24
So i purchased a Corsair A50 and found it was to big after i mounted it on an evga 680i, the case i was trying to get it in is a LIAN LI PC-V1200Aplus II. The Heat sink it self hangs over the motherboard about 1/2 in so i cant get the motherboard to mount. Anyone have this issue and if so what aftermarket heat sink did you use that produced the same level of performance for the price.
