Question about webcams and USB extension cables
beto
Hello all,
I have a friend who is bedridden and without the function of most of his body (he can still use his right arm and hand). He would like to be able to use Skype. The issue is that the head of his bed is probably at least 15+ ft. from his computer (especially when taking into account trying to run a cable along the baseboard if possible). So my question is: will a 720p web cam and a 15ft. USB 2.0 extension cable actually work and allow him to use Skype effectively or is that just asking too much of the extension cable?
I have done some preliminary research and think I read that the max effective range of USB 2.0 is 16.5 ft. So, I am really doubting that a 6 ft. webcam cable attached to a 15 ft. extension would work. Would the extension cable be able to carry enough juice to power the webcam? Would the extended length be able to cope with the digital video signal sent from the cam to the PC?
Anyone help/thoughts would be appreciated. Thanks in advance.
The official limit of a single USB2 run is 5m which according to google is just under 16.5 feet.
Use a 5M A-B cable and a USB hub (that way you have two seperate runs, computer to hub and hub to webcam). I would also make sure the hub has it's own PSU to make sure the webcam gets the power it needs.
Ok, thanks for the suggestion. Not sure how I would get a hub with its own power supply though. Is that a common feature? I will do some more research. Thanks again.
You could also try an active usb cable like this one http://www.newegg.com/Product/Produc...82E16812107304
An active USB extension cable is just a USB hub with only one accessible port and a built-in cable.
IMO it's better to use a seperate hub, that way you can supply the hub with power externally (avoiding volt drop issues) and you have the other ports available if you want to plug in extra devices in future.
In my experiance most hubs have a connection for a power supply but there isn't always one included.
