evening guys.......
I'm to the world of Water Cooling.
I do have one question: I'm really not into overclocking, mainly because I never had the need for it, really, although noise is a big factor for me and that is why I'm considering WC!
I have an Antec P160 case, which has a 120mm fans.
One very important thig is: I really wish not to mod the case in any way! Would it be possible to have a sweet noiseless setup (and a good performer too so I can try overcloking) while maintaing my case intact?
Is the swiftech RadBox worth considering? Never heard anything bad about it!
Would you guys be able to suggest something that will keep me happy?
I can spend as much as $200, give or take.
PS: The setup should be as simple and as safe as possible!
Thanks so much!
Thanks so much!
