Question about water cooling.
hondah22aboi
I'm very skeptical when it comes to water cooling. Never had a Water cooling setup. Always an AirCooler. But I want to change that. Anyone runs watercooling 24/7? Which product is a good start off for a first timer on water cooling? looking to spend around 150 maybe 170 tops. Seperate parts would be ok. Want to water cool my i7 920.
thanks in advance!
This kit is a little more than you're wanting to spend, but it will give you a good start and decent performance. It will be very easy to add or change parts down the road, if you want more cooling.
The Swiftech kits are good too.
The easiest and most fool proof is Aqua gear. The tubes are all push in and they do not leak. Aqua's gear is more expensive but it is top notch and very easy to use.
