So I went all out and dished out $400.00 for a dual radiator water cooling setup. I'm also thinking of buying one of 2Fresh's heater core setups. The loop will run like so...
Pump ---> Rad 1 (Swifttech MCR80)---> GPU ----> Chipset ---> Rad 2 (Swifttech MCR80) ----> Heater Core ----> CPU ----> Fill/Bleed Assembly ---> Pump.
The reason I want so much cooling is because I will be purchasing the MSI K8N Nero Platinum soon, so I can OC my A64 3000+, and I'd like to break some water cooled records. I'm sure there is a better series to run with this kit, but with the space I have and where things will be mounted, this seemed the most logical ... I am up for suggestions though...
Here's my question:
1.) I know if the liquid drops below ambient temp, I will get condensation, which will lead to frying my PC. Does anyone know the possibility that this will happen with this kind of setup??
2.) I'm getting many different readings for my ambient temp. 1st from Riva Turner ambient temp, (39C), which I assume is near the card (9600XT)?? 2nd Sys Temp from MSI Core center (43C)?? Which should I trust, or should I take the middle of the two??
Thanks,
-V
Here's my question:
Thanks,
-V
