I recently purchased a new LCD TV (TOSHIBA 32" 16:9 8ms 1080p LCD HDTV 32RV525R).
I absolutely love the picture quality with my xbox360 and blueray player but sometimes I like to switch my computer over to it and watch movies/shows that I've downloaded. I have a Radeon 4850 video card and I connect to the LCD TV via a DVI to HDMI cable. Now, the first time that I switched the video over to the LCD TV (1920x1080) the image looked very soft and a little blurry. This didn't surprise me because it is a TV after all and meant to be watched from a distance... so whatever, the picture is a little soft/blurry, I'll deal.
I put a blueray movie in my computer because I wanted to see how the picture looked being played off the computer compared to my blueray player, the picture wasn't even in the same ballpark. The picture, when playing the blueray movie on my computer was CONSIDERABLY worse (this is still at 1920x1080 resolution) than my blueray player... Ok, I just assumed that's how it was.
Then I decided to play around with the resolution settings. With my computer still using the LCD TV as a monitor, I switched the resolution from 1920x1080 to 1360x768 (720p I assume?) and instantly the picture was perfectly crisp and clear. Entirely useable from any distance. Now this is where I got confused. My logic was that the reason 1080p looked so soft/blurry when displaying from my computer was because I was simply trying to display so many pixels across a much greater surface.... but that doesn't make sense when you consider that a lower resolution looks SOOO much better. A lower resolution has less pixels to display over a greater area right?
I have searched around and tried to read some guides on aspect ratio and resolutions online but I must admit I'm a bit confused. If anybody could help me understand what I may be doing wrong or where my logic took a wrong left turn I would be very greatful.
Oh and I did try different settings on my TV like dot for dot, native, full, but its all the same soft/blurry image at 1080p when using it as a monitor for my computer... from my blueray player it looks great. EDIT:: Oh and also the blueray movie is definitely 1080p.
