Question about TLER
night_2004
I've got two WD 750GB Caviar Black drives running in RAID 1, and they've been running in RAID1 for about 12-18 months. I've never altered the TLER values on the drives, nor have I ever had a problem with a drive dropping out of the array.
So question is, are these drives just never needing to trigger ECC or is TLER already enabled or is this whole TLER situation just a bit exaggerated?
RAID1 has always been handled via the ICH9R or ICH10R chipset from Intel.
TLER only comes into play when using a parity based array such as RAID5.
You have nothing to worry about.
I'm curious why this doesn't screw with RAID1 then. If the drive is trying to do ECC thus doesn't respond to a read/write, wouldn't the controller assume that one of the drives in RAID1 is faulty?
ECC has nothing to do with HDDs or TLER
I meant that before TLER triggers the computer is doing something trying to correct the error. It was just a loose use of the ECC term.
To be clear here I'm asking about RAID1, not RAID0.
